Renderworks shader parameters
Renderworks textures are composed of four shaders: color, reflectivity, transparency, and bump. The following topics describe the shader parameters.
Color shader parameters
Shader
Description
Object Attribute
Selects the object’s fill color attribute to apply as a color texture
Selects an imported image to apply as a color texture; the image can also be tinted with color (see Using an image in a texture shader)
Color
Specifies a color to be applied as a texture
Color
Click the color box to select the shader color
Brightness (%)
Lightens or darkens the selected color
Fresnel
Can be used to create a texture with a somewhat fuzzy appearance, like that of a pillow that appears slightly darker or lighter on its edges
Edge Color
Select the edge color by clicking the color box
Center Color
Select the main color by clicking the color box
Bricks
Creates a variegated brick pattern
Scale (%)
Specifies the size of the bricks relative to the texture Size
Colors
On the Bricks, Gaps, and Alt Bricks panes, click the color boxes to select color variations within a brick/gap, or choose the same color for no variation
Choose Image
On the Bricks, Gaps, and Alt Bricks panes, click to use an image for the brick or gap texture. The chosen image is randomized to show no repetition on the textured object, so each brick/mortar joint will look realistically unique.
For the completed brick surface to display correctly, the brick image should show only the flat face of a single brick or a portion of a brick, without any mortar joints. The gap image should show only mortar without any brick. Images of clay tiles and other similar objects can also be used in place of a brick.
Delete Image
Removes the selected image from the shader and uses only colors to create the variegated pattern
Image Blend (%)
When an image is used, specifies the blending between the image and the colors selected, to enhance the randomization of the resulting pattern. A low percentage value uses more color in the pattern, while a high value uses more of the image. The selected colors tint the image unless a blend value of 100% is set.
Bricks
Contrast (%)
Sets the color contrast between the two brick colors, establishing the dot-like variation within a brick
Brick Width/Height
Sets the brick width and height in real-world dimensions
Shift (%)
Sets the horizontal offset between rows of bricks
Half Brick Row
Adds a row of half bricks at the specified row interval
Half Brick Shift (%)
For half-brick rows, sets the amount of horizontal shift
Gaps
Size
Sets the size of the mortar joint gap in real-world dimensions
Noise (%)
Specifies the wobbliness of the mortar joints
Alt Bricks
Row
Adds a row of alternate brick colors at the specified row interval
Column
Adds a column of alternate brick colors at the specified column interval. Row must be greater than 0 to show columns.
Grass
Depending on the grass Density and the size of the model, using a grass shader on large surfaces can add significantly to the required render time. For large areas, using only an image shader rather than the grass shader is recommended, or break up the model into a foreground area with grass, and a background area with an image texture or color but no grass shader.
Custom Renderworks and Renderworks styles have an option to deselect Grass, controlling when blades of grass are depicted. Then, only the ground color or ground image is shown, without rendering grass blades. Grass is always off for Fast Renderworks and always on for Final Quality Renderworks.
Colors
The first color box specifies a color for the grass blade base and the ground, when an image is not used. The second color sets the color of the grass blade up to its tip.
Choose Image
Select an image to use for the grass as well as the ground between the blades of grass
Delete Image
Removes the selected image from the shader and uses only colors to create the grass
Image Blend (%)
Length
Determines the length of each blade of grass
Width
Sets the width of the grass blades at the base. Each blade tapers to a point at its tip with a width of zero.
Density (%)
Specifies the grass blade density
Crinkle (%)
Specifies the curliness of the blades
Bend (%)
Curves the blades sideways
Wetness (%)
Makes the blades look shiny/wet
Noise
Pattern
Select the type of noise pattern to use. The preview helps distinguish the differences among the patterns. A generic noise pattern to select is Turbulence. Cell Voronoi is useful for creating speckled noise (set Low and High Clip around 70% each).
An example of each pattern is shown using default values for a color shader on a sphere with warm lighting on the top and cool lighting on the bottom. For comparison, this sphere has no texture applied:
The pattern might look different on a plane as opposed to the sphere used for the example. In addition, the appearance of each pattern can be dramatically affected by changes to its parameters. This example shows three variations of the blistered turbulence pattern.
Pattern
Varying only the Low Clip and High Clip percentages can completely change the appearance of the pattern.
The selected shader type also obviously affects the appearance of the pattern. This example shows the blistered turbulence pattern as a color shader and as a bump shader.
Box
Smoothed, random cube pattern
Blistered Turbulence
Varied distribution of light and dark areas
Buya
Generally dark background with occasional random light areas
Cell Noise
Tiled pattern with high contrast
Cranal
Looping, curving pattern of lines
Dents
Organic, twisted pattern of light and dark areas
Displaced Turbulence
Smooth version of turbulence, with random light and dark areas
FBM
Finer, detailed pattern of random light and dark areas
Hama
Similar to the looping pattern of cranal, but more abrupt and with high contrast
Luka
Mineral-like pattern of rough and more detailed areas
Mod Noise
Similar to the tiled pattern of cell noise, but with less contrast
Naki
Rough, concrete pattern
Noise
Soft, random, and unfocused pattern of wider light areas and some dark areas
Nutous
Generally dark background with smooth, flaked light areas
Ober
A variety of rough and detailed areas, interspersed with looping, flowing lines
Pezo
Generally dark background with smaller, patchy, lighter areas
Poxo
Fine-grained, detailed pattern
Random
Very fine and even detailed pattern
Sema
Generally dark background with random, dripping/melted lines
Stupl
Flowing, smeared pattern of light and dark areas
Turbulence
Soft and smooth, yet detailed noise pattern
VL Noise
Smoothed, varied, less-focused noise pattern
Wavy Turbulence
Smooth, soft noise pattern with occasional random peaks
Cell Voronoi
Similar to mod noise, but with irregular mosaic shapes rather than square tiles
Displaced Voronoi
Organic voronoi pattern with smaller, inner pattern offset
Sparse Convolution
Soft, unfocused, wide pattern of light and dark areas
Voronoi 1
Organic, detailed voronoi pattern of small cell shapes
Voronoi 2
Blurred voronoi pattern with offset secondary pattern
Voronoi 3
Sharp organic voronoi pattern of irregular cell shapes, high contrast with dark outlines
Zada
Twisting, organic pattern with sharp looping areas and flat areas
Wood
Detailed wood-grain pattern
Marble
Marbled, veined pattern with high detail
Colors
Click the color boxes to select color variations within the noise pattern
Scale
Global (%)
Sets the size of the pattern as a percentage of the texture Size
Relative (%) U, V, W
Allows the pattern to be stretched in the U, V, and/or W direction; can be used to simulate the appearance of scratches
Options
Dimensionality
Select 2D Wrapped or 3D Solid. Wrapped shaders are 2D patterns projected onto a 3D object surface. Solid shaders are 3D patterns applied to a 3D object surface; when the shape changes, the object and pattern are still displayed correctly.
Detail
Sets the level of detail or resolution for many of the patterns
Cycles
Creates a repeating pattern of banded noise texture; set the number of repetition cycles to use
Low/High Clip (%)
The low and high clip determine the abruptness of the transition between noise colors and are often set as a combination to achieve a desired effect. Set the Low clip higher or the high clip lower for a sharp transition to the other color; set the clips evenly to make the transition between noise colors more even.
Pavement
Creates the appearance of cracked pavement; with no gaps, simulates variegated pavement, and with the same two colors, simulates solid pavement
Scale (%)
Sets the size of the pavement as a percentage of the texture Size
Stones
Colors
Click the color boxes to select color variations within the pavement, or choose the same color for no variation
Coarse Marbling (%)
Increases or decreases the coarse marbling appearance of the stones
Fine Marbling (%)
Increases or decreases the fine marbling appearance of the stones
Gaps
Colors
Click the color boxes to select color variations within the pavement joints
Width (%)
Sets the width of the pavement joint gap as a percentage of the texture Size
Softness (%)
Sets the bevel amount between pavement stones and pavement joints
Grain (%)
Sets the amount of color variation within the pavement gaps
Smudges
Colors
Click the color boxes to select color smudging variation within the pavement gaps
Amount (%)
Sets the amount of smudging for the pavement gap smudges
Size (%)
Increases or decreases the amount that the smudging extends from the gap centers
Tiles
Pattern
Select the type of tile pattern. The preview helps distinguish the differences among the patterns. Some of the patterns use two of the tile colors, while others make use of all three.
Brick 1
Alternating brick pattern with two colors
Brick 2
Alternating brick pattern with three colors
Circles 1
Alternating polka dot pattern with two colors
Circles 2
Offset polka dot pattern with two colors
Circles 3
Offset polka dot pattern with three colors
Hexagons
Alternating hexagon pattern with three colors
Lines 1
Alternating pattern of lines with two colors
Lines 2
Line pattern with three colors
Parquet
Parquet pattern with three colors
Planks
Alternating rectangular pattern, similar to wood planks, with two colors
Radial Lines 1
Starburst pattern with two colors
Radial Lines 2
Starburst pattern with three colors
Random
Irregular cellular pattern with blends of three colors for a stained glass effect
Rings 1
Alternating circular pattern with two colors
Rings 2
Alternating circular pattern with three colors
Sawtooth 1
Alternating zig-zag pattern with two colors
Sawtooth 2
Zig-zag pattern with three colors
Scales 1
Alternating scale pattern with two colors
Scales 2
Alternating scale pattern with three colors
Spiral 1
Alternating spiral pattern with two colors
Spiral 2
Alternating spiral pattern with three colors
Squares
Alternating checkerboard pattern with two colors
Triangles 1
Alternating triangle pattern with two colors
Triangles 2
Offset triangle pattern with two colors
Triangles 3
Offset triangle pattern with three colors
Waves 1
Alternating wavy pattern with two colors
Waves 2
Wavy pattern with three colors
Weave
Basketweave pattern with two colors
Colors
Click each color box to select the color for the grout, and up to three colors for the tiles
Randomize Colors
Uses randomly-selected colors for the pattern, mixing the selected colors in no particular order
Dimensions
Grout Width (%)
Sets the width of the grout joint as a percentage of the texture
Bevel Width (%)
Sets the bevel amount between tiles and grout
Horizontal Orientation
When selected, tiles are oriented horizontally; deselect for vertical tiles
Scale
Global (%)
Sets the size of the tile pattern as a percentage of the texture Size
Relative (%) U, V
Sets the relative scale of the tile pattern in the U (width) or V (height), allowing the tiles to be stretched
Reflectivity shader parameters
Shader
Description
Specifies an imported image to be used as the reflectivity shader (white is more reflective; black is less reflective); see Using an image in a texture shader
Backlit
This shader is useful for lamp shades, light bulbs, and curtains that are lit from behind. If Cast is selected in the Shadows section of the Edit Texture dialog box, the backlit shader acts as an area light for indirect lighting. If Cast is not selected, the backlit shader does not emit light.
Color
Specifies a color to be applied as a backlit color; click the color box to select the color
Brightness (%)
Controls the backlit brightness
Reflection (%)
Sets the amount of reflection to use, or set to 0 for no reflection
Blurriness (%)
Sets the amount of blurriness for the reflection, or set to 0 for no blur
Glass
Glass shaders usually look best with a dark Color shader combination
Edge Color
Click the color box to set the color applied to the glass at an angle, which is seen at the edge of the glass
Center Color
Click the color box to set the color at the center (main) part of the glass
Blurriness (%)
Glow
The glow shader offers an alternative to creating line or area lights, and can create “neon” signs.
See the video links below.
Brightness (%)
Sets the amount of glow
Emit Light
Allows the texture to become a light source, when Indirect Lighting is enabled (View > Set Lighting Options)
Add Matte Reflectivity
Creates a partially glowing light that is also lit by other light sources
Reflection (%)
Blurriness (%)
Mirror
Mirror shaders usually look best with a dark Color shader combination
Color
Click the color box to select the mirror color; use grayscale for a regular mirror effect, and select colors for mirrored metallic effects
Reflection (%)
Blurriness (%)
Sets the amount of blurriness for the reflection; using a non-grayscale color and some blurriness creates an effective metallic look
Plastic
Color
Click the color box to select the plastic color
Brightness (%)
Sets how bright the shader appears
Roughness (%)
Sets the width of shiny areas on the plastic; increase the percentage for wider shiny areas
Reflection (%)
Blurriness (%)
Cloth
Preset
Select a cloth to base the texture on, or select Custom to create an entirely new cloth texture
Colors
Warp/Warp Highlight
Sets the base and highlight colors for threads running in the warp direction
Weft/Weft Highlight
Sets the base and highlight colors for threads running in the weft direction
Scale and Orientation
Scale U/V(%)
Scales the weave pattern in the U/V direction
Orientation
Rotates the weave pattern
Highlights
Thread Highlight (%)
Controls the width of the highlight on individual threads; smaller values produce sharper highlights, and larger values give more diffuse results
Polyester/Silk Highlight (%)
For a polyester or silk Preset, controls the shape and brightness of the cloth’s characteristic sheen; higher values produce brighter, more blurred highlights
Uniform Scattering Factor
Specifies the overall reflective strength of the cloth; higher values produce more reflective cloths
Forward Scattering Factor
Specifies the reflective strength of the brighter regions of the cloth
Irregularities
Color (%)
Controls irregularities in the warp and weft colors, to create a more realistic appearance for some kinds of cloth
Color Scale (%)
Controls the size of the color irregularities
Warp/Weft (%)
Defines the irregularities in the warp/weft direction of the cloth, to create a more raw-looking weave
Thread Scale (%)
Controls the size of the irregularities in thread directions
Metallic
Creates metallic effects (also try colored mirror shaders for polished metal effects). Metallic shaders usually look best with a dark Color shader combination.
If a legacy Preset metal is selected, metallic effects require the presence of light objects in the drawing; panoramic image Renderworks background lighting will not produce metallic effects.
Preset
Select a metal
Color
If Preset is None or a legacy metal, click the color box to select the metallic color
Metal Reflection (%)
Sets the reflection of the metallic layer.
Metal and clear coat shaders are layered to create complex metals; combine the reflection and roughness of both shaders to achieve the desired result.
Metal Roughness (%)
Sets the roughness of the metallic layer to simulate micro scratches
Clear Coat Reflection (%)
Sets the reflection of the clear coat layer.
Clear Coat Roughness (%)
Sets the roughness of the clear coat layer to simulate micro scratches
Reflection (%)
For a Preset legacy metal, sets the amount of reflection to use, or set to 0 for no reflection
Blurriness (%)
For a Preset legacy metal, sets the amount of blurriness for the reflection, or set to 0 for no blur
Brushed
Creates a brushed metal effect by adding microscopic scratches (not available with Preset legacy metals)
Pattern
Select the pattern that microscopic scratches form on the metal; Radial settings project the scratches in a curve, while Planar rotates them without curving
Scale (%)
Defines the size of the selected Pattern
Orientation
Sets the angle of the scratches; this changes the reflective behavior of the object without repositioning a light source
Offset U/V (%)
Moves the Pattern horizontally/vertically
Primary Scratches
Adds scratches that run parallel to the microscopic scratches; enter the Depth, Width, and Length of the additional scratches
Secondary Scratches
Adds scratches that run perpendicular to the microscopic scratches; enter the Depth, Width, and Length of the additional scratches
Bricks
These parameters are the same for all shaders; see Color shader parameters
Noise
Pavement
Tiles
Glow parameter videos
Transparency shader parameters
Shader
Description
Image Mask
Selects an imported image to apply as a transparency mask (see Using an image in a texture shader)
Selects an imported image to apply as a transparency texture (see Using an image in a texture shader), for colored transparency and projected colored lights like gobo projections in the Vectorworks Spotlight software
Color
Specifies a color to be applied as a transparency
Color
Click the color box to select the transparency color
Brightness (%)
Glass
When using glass transparency, set the accompanying color shader to a dark color (or even black) for best results.
See the video link below.
Transmission (%)
Sets how much light passes through the glass; set to a high value when the glass is very clear
Index of Refraction
As light moves through a medium, the index measures the change in the direction of the light’s rays. An index of 1.0 indicates no change; a typical value for water and ice is 1.3, and for glass use 1.5–1.6.
To save time, use a value of 1.0x (just above 1) when the glass is thin.
Color
Click the color box to select the color that appears in a very thin object; for glass, this is usually set to white
Blurriness (%)
Blurs the transparency by the specified amount, or set to 0 for no blur. Blurred glass appears frosted (and takes longer to render).
Absorption Color
Click the color box to select the color that a large, thick object assumes, when a ray of light has traveled the Absorption Distance
Absorption Distance
Defines the distance rays of light have to travel before Absorption Color replaces Color. The lower the value, the more intense the Absorption Color is. This applies to thick or thin glass.
Plain
Provides plain, uniform transparency of a specified amount
Opacity (%)
Sets how opaque the shader is; set to a lower value for more transparency and to a higher value for more opacity
Rectangular Mask
Uses the texture as a rectangular mask to apply as a transparent texture (usually combined with another shader to create a specific masking effect). Useful for decals.
Horizontal/Vertical Repetitions
Indicates how to display the mask: a single instance, infinite repetitions, or a set number of repetitions in each direction
Shadow Catcher
Catches shadows and/or reflections that fall onto the object the shadow catcher is applied to in the alpha channel, so they show on an invisible ground plane. Rendered images with the shadow catcher can be composited with a rendered or photographic image file that has the alpha channel enabled to produce realistic shadows and reflections.
Objects that have a shadow catcher texture render black in Vectorworks, but everything other than the shadow/reflection is transparent in the composited image.
The shadow catcher cannot be used when rendering with a visible Renderworks background in a viewport. Shadow catcher textures can be used in design layers with a visible Renderworks background.
Catch Shadows
Captures shadows of rendered objects; deselect to show only reflections
Shadow Strength (%)
Controls the transparency of the shadows; lower values are recommended for more realistic shadows (0 shows no shadow and 100 is opaque)
Shadow Color
Specifies the color of the shadow; for daylight scenes, a dark blue is recommended for more realistic shadows
Uniform Shadow Strength
Sets all shadows the same color/intensity regardless of light source; deselect if multiple light sources are used, for more realistic shadows
Reflection Strength (%)
Controls the intensity of the reflections included in the alpha channel; 0 shows no reflections
Bricks
These parameters are the same for all shaders; for a description, see Color shader parameters
Noise
Pavement
Tiles
Glass parameter video
Shadow Catcher parameter video
Bump shader parameters
Shader
Description
Specifies an imported image to be used as the source of the bump map displacement (see Using an image in a texture shader)
Bricks
Many of these parameters are the same as for Color shader parameters; additional bump-specific parameters follow
Noise
Pavement
Tiles
Parallax Offset (%)
Sets the amplitude of the parallax mapping. Positive and negative values can be entered.
Parallax mapping enhances bump mapping by giving textures such as bricks more apparent depth, without the performance slowdown that can be associated with displacement mapping. Unlike displacement mapping, parallax mapping appears flat in silhouette.
Displacement Mapping
For realistic bump textures, displacement mapping creates texture and bumpy details with a rendering technique that appears embossed, projecting the geometry outward from the surface.
This mapping applies only to Final Quality Renderworks and Custom Renderworks when Displacement Mapping is enabled in the render options. Rendering can be significantly slower with displacement mapping.
If an image bump does not provide the desired results, try a noise bump shader.
Height
Specify a non-zero height to enable displacement mapping; large height values may result in longer render times
Detail
Sets the level of detail for displacement mapping; requirements and results vary depending on the texture and the surface’s face size. Textures without too much bump detail and a large face size, such as boards or stones, render with less detail and can be set with a lower level of detail; fine, faceted textures like grass or leaves may require a high level of detail, which also requires more rendering time. Conversely, very large surfaces, like a ground plane, may need higher levels of detail to see the displacement.
Self-Shadowing
Adds shadows to the displaced geometry, increasing realism as well as rendering time
Creating a new texture
Editing textures and shaders
